10 night-sky targets to spot in the beautiful Summer Triangle star patter
A list of the many deep-sky delights waiting to be discovered in one of summer’s most familiar star patterns.
The Summer Triangle is one of the best-known asterisms in the night sky.
Made out of three bright stars – Deneb, Vega and Altair – it’s often among the first star patterns that newcomers to astronomy identify, because it’s so obvious to the naked eye.
10 targets to spot in the summer triangle. Credit: Pete Lawrence
Use our labelled chart to help you locate our top 10 targets in the Summer Triangle. Credit: Pete Lawrence
More experienced observers love it because a host of celestial summer sights can be found inside and around it, all of which are visible to the naked eye or through binoculars.
Wait until the darkest time of the balmy summer nights and look out for these 10 of the best.
10 targets to spot in the Summer Triangle
1. North America Nebula
The North America Nebula Reza Hakimi, Moomej, Iran, 10, 11 July 2018 Equipment: ZWO ASI1600MM-C camera, Canon EF 200mm f/2.8 lens
Credit: Reza Hakimi
To the left of Deneb you’ll see, out of the corner of your dark-adapted eye, a large smudge around four times as wide as the Moon, known as the North America Nebula. Through a small telescope this huge, faraway cloud of gas and dust, NGC 7000, looks like North America.
2. Veil Nebula
The Veil Nebulae, Matthew Clough, Selby, North Yorkshire, 23 June 2021. Equipment: ZWO ASI 294MC Pro camera, William Optics RedCat 51 refractor, Sky-Watcher HEQ5 Pro mount
Credit: Matthew Clough
About 10,000 years ago, a huge star blew up in a supernova. All we can see of it now are faint arcs of misty light, known as the Veil Nebula Visible faintly through binoculars, it is best seen through a telescope, especially its brightest and densest sections.
3. Cygnus Star Cloud
Cygnus star cloud. Credit: Bernhard Hubl / CCDGuide.com
Running down the right side of the Northern Cross, this star cloud looks like it has been airbrushed on the sky by some astronomical artist. Switch to binoculars or small telescopes and it resolves into countless faint stars.
4. M27
The Dumbbell Nebula, Francis Bozon, remotely via Alentejo Remote Observatory, Portugal, 4 August - 28 September 2022 Equipment: Moravian G3-16200 camera, Astrosib RC 400 Ritchey-Chretien telescope, ASA DDM85 direct-drive mount
Credit: Francis Bozon
Seventh-magnitude M27, the Dumbbell Nebula, is often hailed as the most beautiful planetary nebula in the sky. It is visible in binoculars, but telescopes will reveal hints of its pale green colour.
5. The Coathanger
The Coathanger by José J. Chambó, Hoya Redonda, Valencia, Spain. Equipment: GSO 8
Credit: José J. Chambó
This small asterism is a spray of several dozen stars, the 10 brightest of which really do form the shape of a celestial coathanger! Almost all of the stars in the Coathanger asterism are blue, but one marmalade-orange star really stands out.
6. Albireo
Double star Albireo Tony Moss, Downham Market, Norfolk, 8th June 2022 Equipment: Altair 269 C camera, Altair Ritchey-Chretien 8in scope, Celestron AVX mount
Credit: Tony Moss
Albireo is one of the most popular double stars because of the contrasting colours of the pair – one a lustrous gold hue, the other a rich, azure blue – which are very obvious through even a small scope.
7. M56
Globular Cluster M56 by Ron Brecher, Ontario, Canada. Equipment: SBIG STL-11000M, Baader LRGB filters, 10
Credit: Ron Brecher
Although overshadowed by larger, brighter M13 nearby, this is still an attractive misty globular cluster in binoculars and small scopes. It lies 31,000 lightyears away and is a ball of thousands of suns.
8. M57
M57 the ring Nebula. Credit: Christoph Kaltseis / CCDGuide.com
Look at this planetary nebula through binoculars or small telescopes and you’ll see why it’s known as the Ring Nebula: it is a small, oval, light grey smoke ring. This shell of gas and dust blown out by a dying star is around 2,300 lightyears away, and glows at magnitude +8.8.
9. Vega
Vega and the surrounding stars through a telescope. Taken with a guided setup, the vista appears sharp, with stars like pins. Credit: Ade Ashford.
With a magnitude of +0.03, Vega is the fifth-brightest star in the sky. A blue-white star 25 lightyears away, it is also known as the Harp Star because of its position within the Lyre. In 210,000 years it will become the brightest star in the sky, shining at magnitude –0.8.
10. Epsilon Lyrae
star epsilon lyrae double double
This fifth-magnitude double star can be found very close to Vega, and can be split easily with binoculars and even with the naked eye if your eyesight is good. Epsilon Lyrae is often referred to as the Double Double, because each of its members is also a double star.
This guide originally appeared in the July 2023 issue of BBC Sky at Night Magazine.
