Animation processing: how to turn your astronomy photos into animations
Published: January 11, 2012 at 12:00 pm
Turn your astro image, like this one of Jupiter, into animations.
Some bodies in the Solar System change their appearance over very short time-scales.
Mars, Jupiter and Saturn fall into this category: their fast rotations drag features on their visible surfaces around their globes at a frenetic pace.
The Sun viewed in the hydrogen-alpha wavelength of light is another good example, as here features can change appearance in timescales of minutes or even seconds.
Capturing these changes in a sequence of still images and presenting them in a strip or grid display can show the changes well.
However, the images really come to life when they are put together in the form of an animation.
This can produce results that far exceed expectations.
There are many ways to produce animated sequences, and many different ways to store them.
A popular technique is to produce what’s known as an animated GIF file, GIF being a web-friendly image file format that supports animation.
A movie file is another popular way to bring together still files to show motion.
The freeware application Registax will create AVI movie files from processed still images for you.
The benefit of using a program like Registax is that it can remove a lot of the hard work you’d otherwise need to do to create a smooth-flowing sequence of aligned frames.
A successful animated sequence starts at the point of capture.
Here, you must decide on how many captures you’re aiming for, how frequently you’re going to take them and how long each one is going to be.
The answers to these questions are also affected by external factors such as the amount of free space on your hard disk, the highest uncompressed frame rate your camera can achieve, the image scale used (how much the target looks magnified) and the nature of the object or event you’re trying to capture.
A sequence of 30s captures taken at one-minute intervals and covering an hour of rotation on Jupiter will show about a tenth of the planet’s rotation and generate 60 capture files, each 30s long.
Processing these files isn’t a job for the faint-hearted, although batch-processing can help – something that the freeware program AVIStack 2 is particularly good at.
Arduous though the task of processing many AVI captures may be, once you have your still frames to hand, the exciting part of creating an animation from them can begin.
There are lots of different programs that can be used here, such as AnimateGIF (freeware), Registax itself and various commercial applications.
Adobe’s ImageReady package, which used to ship with Photoshop, was particularly good at the task, allowing you to load each frame into a single file as a separate layer.
ImageReady was discontinued with Photoshop CS3, but its functionality lives on in later versions.
Although our basic step-by-step process is based around later versions of Photoshop, the preparation and alignment routines described can be used with any animation program that supports flick-book style animation.
Read more about creating animations of lunar eclipses
How to create a GIF animation from a sequence of planetary captures
This article is an extract from Part 2 of our series of in-depth guides to image processing techniques.
To read the rest of the article, see the February 2012 issue of Sky at Night Magazine
