Missing Comet Pons Brooks? Asteroid 2 Pallas is at its best in May and can be seen with a small telescope
Small scopes can easily track 2 Pallas as it arcs beneath the Keystone all month.
Published: April 30, 2024 at 10:24 am
Minor planet 2 Pallas reaches opposition on 17 May when it can be found shining within the stars of Hercules at magnitude +8.9.
At this brightness, it’s a tricky binocular find, but a small telescope should pick it up without any difficulty.
Find out what comets and asteroids are visible tonight
Chart showing location of Asteroid Pallas in May 2024. Credit: Pete Lawrence
Chart showing location of Asteroid Pallas in May 2024. Click to expand. Credit: Pete Lawrence
Pallas is one of the so-called ‘big four’ asteroids, referencing the first four to be discovered: 1 Ceres, 2 Pallas, 3 Juno and 4 Vesta.
Now that many more examples have been found, it has been demoted to 10th-largest, with a mean diameter of 513km.
On 1 May, Pallas is at mag. +8.9 and located 3° northeast of Kornephoros (Beta (β) Herculis).
Its track then takes it northwest, arcing gently across the area south-southwest of the famous Keystone asterism formed from Epsilon (ε), Zeta (ζ), Eta (η) and Pi (≠) Herculis.
Asteroid Pallas reaches opposition on 17 May, which means its on the opposite side of the Sun in the sky.
At the end of the month, Pallas just manages to reach the border between Hercules and Corona Borealis, maintaining brightness and ending its May track at mag. +9.0.
Pallas asteroid Very Large Telescope, 24 February 2020 Credit: ESO/M. Marsset et al./MISTRAL algorithm (ONERA/CNRS)
An image of the Pallas asteroid, by the Very Large Telescope, 24 February 2020 Credit: ESO/M. Marsset et al./MISTRAL algorithm (ONERA/CNRS)
Asteroid Pallas facts and history
Pallas was discovered by Heinrich Olbers on 28 March 1802.
Interestingly, Charles Messier, the originator of the Messier Catalogue, recorded it 23 years earlier while tracking a comet.
Messier noted the object, but thought it was a star – causing its anonymity to be preserved.
Pallas’s discovery was given a helping hand by the discovery of the first minor planet, 1 Ceres (since promoted to dwarf planet).
Dwarf planet Ceres. Credit: NASA/JPL-Caltech
Dwarf planet Ceres, as seen by NASA's Dawn mission. Credit: NASA/JPL-Caltech
Ceres was discovered in 1801 by Giuseppe Piazzi, who initially believed he had recorded a comet.
However, studies showed that the motion of Ceres was odd and quite unlike any comet seen before.
After several months being lost from sight, Ceres was recovered later in 1801 by Baron von Zach and Heinrich Olbers.
It was while attempting to relocate Ceres a few months later that Olbers stumbled across Pallas, its discovery fortuitously helped by the fact that it was positioned near Ceres at the time.
This guide originally appeared in the May 2024 issue of BBC Sky at Night Magazine
