Make a telescope mount counterbalance system
Construct a home-built unit that will improve the tracking accuracy of your mount
Our special issue The Big Book of DIY Astronomy Projects is out now. Click here to buy
A well-balanced mount will track to the best of its ability and will improve Go-To accuracy, especially if you are guiding for long exposures during deep-sky astrophotography as it will allow guiding corrections to be made with minimum effort.
For an equatorial telescope mount, both the right ascension (RA) and declination (dec.) axes require balancing to avoid over-stressing the drive motors and gears in a conventional drive train, or to avoid slippage in a friction drive mount.
A balance bar is a simple way of allowing easy and safe balancing of the dec. axis.
Here we'll show you how to make your own DIY telescope counterweight system from readily available components and some basic tools.
For more guides like this, visit our DIY Astronomy webpage.
Make a telescope mount counterbalance system in use
The finished counterbalance system in use.
Balancing RA and dec
Adjusting the balance of the RA axis is simple as it is just a matter of moving the counterbalance weight (or weights) up or down the counterbalance shaft until balance is achieved.
However, balancing the dec. axis is more challenging as this entails moving the telescope forwards or backwards in its dovetail clamp.
There is also some risk as the clamp that safely holds your scope on to the mount head needs loosening.
With some telescopes, achieving dec. balance conventionally can be difficult or even impossible, especially with the short focal length instruments used with heavier cameras for wide-field imaging.
This is because many of these instruments are supplied with short dovetail bars that simply don’t allow enough movement in the clamp.
Add in the complication of a guidescope and the problems begin to multiply. This is where our simple yet effective counterbalance system comes into its own.
telescope mount
Once you've added your telescope and guidescope, balancing the overall setup can be tricky.
How the mount counterbalance works
The concept is straightforward – there’s a second dovetail clamp mounted on top of your telescope’s tube rings, which has a small counterbalance weight mounted on a long dovetail bar.
This slides through the clamp until balance is achieved.
A Vixen-style dovetail bar is ideal for this as it’s sturdy enough for the task and doesn’t contribute too much weight in its own right.
Suitable clamps are available from many astronomical suppliers.
Explore Scientific camera dovetail
The Explore Scientific camera dovetail bar
Depending on the telescope and camera or eyepieces that you want to mount and balance, along with the length of the supplied dovetail bar, you may find that additional weight is required at either the front or the back of the telescope.
Always try to balance the equipment on the dec. axis as best you can first and make a mark on the dovetail bar and clamp to show the best position for future use.
If balance cannot be satisfactorily achieved then this project will come to the rescue as it will allow you to add additional weight to either the front or back.
Once the dec. axis is balanced, adjust the RA axis balance by sliding the mount’s counterbalance up or down the counterbalance bar.
If you are using an autoguider and a gear-driven mount, bias the RA axis to be slightly counterweight-heavy on the ‘rising’ side.
  • 33.5cm dovetail bar
  • Dovetail clamp (size suitable for mounting on top of the tube rings)
  • A counterbalance weight
  • 6mm bolt long enough to pass through the counterbalance weight
  • 6mm washer
  • Large Nyloc nut for use as a spacer
  • 2 x bolts to attach the dovetail clamp to the tube rings
  • Tape measure or steel ruler, masking tape and a pencil
  • Electric drill or pillar drill
  • 6mm drill bit and countersink cutter
  • 6mm tap tool
Make your counterbalance system, step-by-step
Make a telescope mount counterbalance system 01
Measure the gap between the bolt holes on the top of your tube rings.
Attach masking tape to the new dovetail clamp and transfer this measurement to the clamp, centring it both longitudinally and laterally.
Work out the thread size in the tube ring bolt holes.
Make a telescope mount counterbalance system 02
Drill and countersink two holes with a diameter of half a millimetre greater than the bolt size, in the marked positions on the dovetail clamp, ensuring that the holes are vertical.
Use a vertical drill stand with a wood block placed under the clamp.
Make a telescope mount counterbalance system 03
Drill and tap a 6mm hole, 65mm from one end of the dovetail bar.
Do a trial fit of the counterweight to the dovetail bar with a 6mm bolt, washer and Nyloc nut.
Shorten and tidy up the thread on the bolt to ensure that it doesn’t protrude through the dovetail bar.
Make a telescope mount counterbalance system 04
Set the mount in its ‘Park’ position with the counterweight(s) down and the scope pointing up, and slide the counterweight(s) down the counterweight bar away from the scope to make the weight side heavier.
It’s now safe to add weight to the scope side.
Make a telescope mount counterbalance system 05
Align the dovetail clamp with the top of the tube rings and do a trial of bolting the two together, making certain that the bolts are not long enough to pass right through the tube rings.
Shorten and tidy up the bolt threads, then refit the bolts and tighten them.
Make a telescope mount counterbalance system 06
Slide the dovetail bar with the balance weight attached into the dovetail clamp, placing the weight on the side that needs to be heavier to attain declination (dec.) balance.
Adjust the balance bar until the dec. axis is balanced, and then balance the RA axis.
This guide originally appeared in the October 2021 issue of BBC Sky at Night Magazine.
