The Flower Moon is the name given to the full Moon in May, which rises this weekend, 1st May and 2nd May 2026 just after sunset.
This full Moon will be visible low in the east after the Sun sets below the horizon, climbing to the southeast as midnight approaches.
The May 2026 full Moon is also a 'micromoon', because the Moon is at its furthest point from Earth, making it appear smaller than usual.
A bright full Moon is one of the most beautiful, arresting sights in nature, and luckily we get to see one once a month.
Find out when the next full Moon is and sign up to the BBC Sky at Night Magazine e-newsletter for weekly stargazing advice delivered to your inbox.
Not every stargazer or astronomer loves a full Moon, though.
A bright full Moon makes targets like meteor showers and deep-sky objects like galaxies and nebulae harder to see, so often you'll find practical astronomers prefer to observe the night sky when the Moon is out of the way.
That aside, a full Moon is a beautiful sight, and certainly something worth taking the time to gaze at every month.
In this guide we'll look at what the Flower Moon actually means, when to see it and how to make the most of it.
Flower Moon 2026 rise times around the world
The Moon reaches its full phase on 17:23 UTC, which may not match when the Moon rises above the horizon, depending on your location.
Nevertheless, once the Flower Moon does rise above the horizon on 1 May, it will be a glorious full Moon.
Here are the rise times for the Flower Moon 2026 in key cities across the world.
| Region | City | Moonrise (local time) |
| North America | New York City | 20:16 |
| Toronto | 20:48 | |
| Los Angeles | 20:03 | |
| UK & Ireland | London | 20:46 |
| Edinburgh | 21:21 | |
| Cardiff | 20:59 | |
| Belfast | 21:27 | |
| Dublin | 21:19 | |
| Europe | Paris | 21:24 |
| Berlin | 20:53 | |
| Madrid | 21:20 | |
| Australia | Sydney | 16:39 |
| Asia/Middle East | Dubai | 18:42 |
| Singapore | 18:46 | |
| New Delhi | 18:48 |
Why it's called a Flower Moon
The term Flower Moon, while it sounds very romantic, doesn't actually mean the full Moon will look any different compared to other full Moons.
'Flower Moon' is thought to be a reference to the fact that it's May's full Moon, May being the time when flowers begin to bloom in earnest and spring is well and truly in full swing.
Each full Moon of the year has its own informal nickname, ranging from the innocent-sounding Pink Moon and Strawberry Moon to slightly more wild Wolf Moon and Hunter's Moon.
Observing the Flower Moon
The 2026 Flower Moon will rise in the southeast just as the Sun is setting on 1 May.
It will be located in the constellation Libra, just below Virgo and its famous 'Bowl of Virgo' star pattern.
The Moon will then work its way across the southern part of the sky, before setting in the southwest in the early hours around dawn.
Because the full Moon is opposite the Sun in the sky, it mirrors the path the Sun takes.
That means that, in winter, when the Sun's apparent path across the sky remains relatively low, the Moon's apparent path is higher.
And because the Flower Moon rises at the height of spring, when the Sun's path across the sky is getting higher, this full Moon will be relatively low in the sky.
That means you'll likely need a clear southern horizon to see it.
A micromoon
May 2026's full Moon, the Flower Moon, is what's known as a 'micromoon'.
It's named as such because it's further away from Earth than normal, and this is all to do with the Moon's orbit around Earth.
The Moon orbits Earth in an elliptical – or egg-shaped – path, so sometimes the Moon is closer to Earth than at other times.
This 2026 Flower Moon occurs at 'apogee', the point at which the Moon is furthest from Earth in its orbit.
An apogee Moon appears around 14.1% smaller and 30% dimmer than the Moon at 'perigee' – when it's closest to Earth – and leads to 5cm smaller spring tides.
Take a look at the Flower Moon. Does it seem smaller to you?
May's blue Moon
Because the Flower Moon rises on 1 May, and because there's only about 29.5 days between each full Moon, that means we'll get a second full Moon in May 2026.
That makes the full Moon after the Flower Moon a so-called monthly blue Moon.
As a result, we'll be getting 13 full Moons in 2026, rather than the usual 12.
Should you observe a full Moon?
Often you'll head astronomers and stargazers saying the Moon is at its worst for observation when it's full, and that a crescent or gibbous phase is much better.
That's because during then non-full phases the terminator - the line dividing the lit and unlit portions of the Moon - throws light and shadow on lunar features, making them much easier to see.
During a full Moon the surface of the Moon is flooded in light, making its topography much more difficult to discern.
And yet a full Moon is a beautiful thing, and something a lot of us probably take for granted.
In the days before street lighting, the bright full Moon must have been a welcome companion for people making journeys at night.
It is a beautiful target to observe and a great one for kids and newcomers to astronomy.
Find out more about this in our guide on what to see during a full Moon and scroll down for more ideas.
The Moon illusion
The Moon illusion is the name given to the fact that a full Moon close to the horizon looks especially large.
The apparent size of the Moon is so much bigger when it's low down, and the effect of this can be quite startling.
This is an optical illusion and is probably caused by the fact that the Moon is much closer to foreground objects like trees and buildings, and so seems to dwarf them, emphasising the Moon's size.
Observe the Flower Moon rising at the end of May and see if it looks much bigger to you.
An orange Moon?
The Flower Moon may be an orange Moon, if you catch it right.
Another phenomenon that occurs when the Moon is close to the horizon is that it can sometimes appear rust-coloured.
Low down, the Moon appears orange or red, and this is to do with sunlight bouncing off the Moon and passing through Earth's atmosphere.
When it's closer to the horizon, Moonlight has to pass through a thicker part of Earth's atmosphere to get to our retinas.
This causes scattering of blue and violet light, meaning that what Moonlight does make it through appears redder.
Take a look at the Flower Moon when it's rising and setting. Does it appear huge and orange? That's the Moon illusion and an orange Moon in one go!
Lunar halo
You may see a bright halo around the Moon when you step outside to observe a full Moon, and this is a well-known phenomenon.
It occurs because light from the Moon is passing through surrounding clouds, causing the appearance of haloes or rings of light and other atmospheric phenomena.
If you're observing the Flower Moon, can you spot any tricks of light caused by the bright lunar glare?
Observe, sketch, photograph the full Moon
Head out and observe the full Moon and get to know its many interesting features.
Even a modest pair of binoculars will give you a closer look, enabling you to explore craters and the lunar maria - or seas.
Then observe the Moon throughout the weeks ahead and see how the phases of the Moon throw shadows on some of those same craters, causing them to appear much differently.
See if you can spot the moonlanding sites with our guide to locating the Apollo landing sites on the Moon.
Sketch the lunar surface then compare your sketchings with family and friends. Find out more in our guide on how to sketch the Moon.
Or photograph the Moon. You don't need a fancy DSLR to capture an image of the Moon.
If you have a smartphone tripod - or can balance your phone steadily while it's pointed at the Moon - and if your phone's camera has a 'pro' photography mode, tweak the ISO, white balance and exposure time and see what you can achieve.
Read our guide on how to photograph the Moon with a smartphone for more advice.
If you do manage to capture an image of the Flower Moon, don't forget to send us your images.
