How to clean a reflector telescope
Ensure your reflecting telescope is delivering the best views of the night sky with our cleaning tips.
Published: September 10, 2015 at 11:00 am
Keeping your telescope clean can become an obsession, but it pays to take care of these valuable instruments.
The open tube design of a Newtonian reflector makes it easy for dust to accumulate on the mirrors, especially the primary.
Storing your telescope in a cupboard with the dust caps on the tube end and eyepiece holder can help to prevent it building up.
Even with careful use and storage, your mirrors will still slowly attract a layer of dust over time, but this is rarely enough to have any obvious detrimental effect on the view.
The general advice is to leave well alone as a scratched mirror will be far more of a problem than a dusty one!
Large dust particles can often be removed using a high-power puffer to direct a strong blast of air at the offending area.
However, pollen, small pieces of foliage and even dead insects can add to this dust and when you start to mix in moisture from dew or rain droplets, these foreign bodies can dissolve and attach themselves to your mirror’s surface.
This is the time to consider taking the plunge and cleaning your mirrors.
It’s important to ensure that no damage is done to the coating on the mirror’s surface.
No chemical or abrasive should be used and you can do an excellent job with just water and a mild detergent.
Clean towels - Rest the mirrors on these while they dry.
Distilled water - Distilled water should be used for the final rinse. Although not always readily available locally, it can be bought from good hardware stores.
High-grade (BP) cotton wool - Cotton wool is needed to clean the mirror safely.
Screwdrivers, Allen keys and pen - You’ll need screwdrivers and Allen keys to disassemble the telescope and an indelible pen and masking tape to ensure accurate alignment during re-assembly.
Tepid water - You need warm water and a kitchen sink with a draining rack, a clean plastic washing-up bowl for protecting the mirrors and washing-up liquid.
Remove the mirror
First, remove the primary mirror by undoing the screws around the rim of the telescope base and taking out the primary mirror cell.
The mirror is held into the cell with three or more mirror clips, which are usually retained by two small bolts.
These can be removed to release the mirror.
Before removing the clips, indelibly mark the vertical edge of the mirror and the cell to ensure that you then reassemble in the same position.
Start the cleaning process by standing the primary mirror on a towel next to the washing area.
With the telescope set horizontally, the secondary mirror can be removed by very carefully holding the edge of the mirror and undoing the centre screw on the spider vane.
You can then slowly take out the mirror.
Gently does it
To ensure that there is no danger of chipping the edge of the mirrors, they should be cleaned in a freshly washed plastic bowl as a precaution.
The two mirrors should always be cleaned separately.
First soak them in tepid water, and a small amount of detergent, for about five minutes to loosen some of the dust and other particles in readiness for the main cleaning.
After each stage of the cleaning process, the mirrors should be carefully rinsed in tepid water and then placed on a soft, clean towel with the mirror surface at an angle.
Replenish the contents of the plastic bowl with fresh water after each part of the process has been completed.
The most delicate part involves carefully dragging pieces of well-soaked cotton wool across the mirror surface under their own weight in a series of strokes.
You should continue until the whole surface has been treated, but it is important to throw each piece of cotton wool away after every stroke.
You can then start the next with a fresh piece.
Under no circumstances ‘scrub’ the surface. Simply let the weight of the cotton wool do the job for you.
Finally, rinse the mirror surface generously with distilled water to ensure that no calcium or other deposits from the tap water can be left to solidify on the mirror’s surface.
Then rest the mirror, supported at a steep angle, on a fresh towel and leave it to dry.
Re-assemble the telescope and collimate it. If you need help with this, read our guide on how to collimate a Newtonian telescope.
This How to originally appeared in the January 2011 issue of BBC Sky at Night Magazine.
