The Lyrid meteor shower is currently at its peak. Here's how to see a shooting star tonight.
With the Moon out of the way during peak activity, this year's Lyrid meteor shower is the first many good showers throughout 2023.
The Lyrid meteor shower is active between 16 and 25 April, with the 2025 peak predicted for 14:00 BST (13:00 UT) on 22 April.
As a result, the best rates for this year's Lyrid meteor shower are likely to be seen during dawn on the morning of 22 April, or all night tonight.
Find out when the next meteor shower is happening and read our guide to what causes a meteor shower.
Get weekly Moon phases and times delivered directly to your email inbox by signing up to receive the BBC Sky at Night Magazine e-newsletter.
Chart showing the location of the radiant of the Lyrid meteor shower 2025
Chart showing the location of the radiant of the Lyrid meteor shower 2025. Credit: Pete Lawrence
What causes the Lyrids
The Lyrid meteor shower occurs when Earth passes through the dust debris stream strewn around the orbit of comet C/1861 G1 Thatcher.
At its peak, the shower produces a zenithal hourly rate (ZHR) of around 18 meteors per hour.
When observing meteor showers, the Moon is key. If the Moon is big and bright, it will diminish the amount of meteors you can see.
Trails of the Lyrid Meteor Shower. Credit: Adventure Photo / Getty Images
During the peak of the 2025 Lyrids, the waning crescent Moon rises as dawn is underway, so won’t interfere this year.
A meteor shower’s visual hourly rate is affected by the altitude of the shower radiant (the area of sky from which the shower’s trails appear to emanate).
For the Lyrids, this reaches a peak altitude at dawn, rising over 60° above the southern horizon. Unusually, the Lyrid peak doesn’t actually occur within the constellation Lyra, but rather within neighbouring Hercules.
The apparent misnaming occurs because the shower was named before the modern official constellation borders were drawn up by the International Astronomical Union, the peak originally being associated with Lyra.
Observing the Lyrid meteor shower
Deneb is a member of the Summer Triangle and the Northern Cross asterisms. Credit: Pete Lawrence
When talking about meteor showers, the 'radiant' is the point in the sky from which the meteors appear to emanate.
The Lyrid meteor shower's radiant is in the constellation Lyra, and you can find it between the Summer Triangle asterism and the constellation Hercules.
Lyrid meteors appear to emanate from the radiant position, southwest of bright star Vega (Alpha (α) Lyrae), which can be found in the constellation Lyra.
Vega is also part of the star pattern - or asterism - known as the Summer Triangle.
This makes it particularly easy to trace a trail back to see whether it did indeed come from the radiant location.
Technically, the radiant sits in Hercules at the time of peak activity.
Use star Vega to find the Lyra constellation and help you spot a Lyrid meteor. Credit: Bernhard Hubl / CCDGuide.com
Zenithal Hourly Rate explained
While you can predict when a shower’s peak period of activity will occur, you cannot specify exactly when and where individual meteor trails will be seen.
The number of trails expected during a shower’s peak period is expressed by a quantity known as the Zenithal Hourly Rate (ZHR).
A ZHR value is calculated by noting the number of shower meteors seen in a set period of time. Shower trails emanate from a small area of sky known as the shower radiant.
However, the ZHR value assumes perfect placement of the radiant, overhead at the zenith.Among other things, it also assumes perfect skies and your ability to see the entire sky in one view.
It varies depending on sky quality, date and time of day.
In practice, few of these conditions is met, so the experienced visual hourly rate (VHR) will be less than the quoted ZHR.
You don't need any fancy equipment to see a meteor shower. Your naked eye is best. Credit: Shimpei Yamashita / Getty Images
How to see a Lyrid meteor
To observe the Lyrid meteor shower:
  • Find a place away from any stray lights
  • Give yourself at 20 minutes in total darkness for your eyes to dark adapt
  • Avoid looking at bright light sources such as a mobile phone
  • Use a garden recliner or an astronomy chair that avoids you straining your neck to look upwards
  • Stare up at an angle of about 60˚, two-thirds up the sky from horizon to zenith
  • Look in any direction, but preferably the one in which the sky looks darkest.
  • Aim to observe for periods of at least 30–60 minutes between short breaks.
  • If you spot a meteor whose trail heads back towards the radiant point, you've seen a Lyrid!
Lyrid meteor seen above Schermbeck, Germany. Credit: Mario Hommes/DeFodi Images via Getty Images
What is a meteor shower?
We see a meteor in the sky when a small particle - on average about the same size as a grain of sand - vaporises in Earth's atmosphere. The path of light across the sky is known as a meteor trail.
Most meteor showers are associated with comets, but some are linked with asteroids, such as the Geminid meteor shower, which is associated with 3200 Phaethon.
As a comet repeatedly orbits the Sun, it spreads dust around the orbit.
Earth passes through these dust streams as it orbits the Sun, causing particles to vaporise in the atmosphere. When this happens, the number of trails we can see increases.
A Lyrid meteor and the Milky Way, Anza-Borrego Desert, California. Credit: Kevin Key / Slworking / Getty
We experience peak activity of meteor showers when Earth is passing through the most dense section of the stream.
Meteor trails appear to come from a specific area of the sky, which is known as the 'radiant'. This slowly moves over the duration of the shower.
The constellation in which peak activity appears to occur is what gives each meteor shower its name.
You might have heard of the Perseid meteor shower, for example, which shows peak activity when the radiant is in the constellation Perseus.
Share your Lyrid meteor shower experiences and images with us by emailing contactus@skyatnightmagazine.com
