Make a Moon phase calculator and calendar
Make a mechanical instrument that calculates and displays the phase of the Moon for any chosen day of the year.
This project is Moon phase calculator, a mechanical instrument that ‘calculates’ and displays the predicted phase of the Moon for any chosen day of the year.
Our design uses a GT2 timing belt and pulleys – commonly used in printers and readily available online – to generate the movement
And we have provided downloadable plans and extra photos and diagrams below, so the build should be straightforward.
The phases of the Moon. Credit: Yaorusheng / Getty Images
To use the Moon phase calculator turn the year ring so that the wire pointer aligns with the date you are interested in.
When you then look into the viewing tube you will see that the painted Moon ball has turned to reveal the predicted phase.
For more astronomy advice, read our guide on how to observe the Moon.
Extra materials to aid your build
Image gallery
To build your Moon phase calculator, you will need:
A ruler, compasses, pencil, coping saw, drill and range of bits, and a small sanding drum attachment
A sheet of 6mm MDF or plywood (200 x 200mm), a piece of board for the base, softwood offcuts for the sanding jig and tube stand, a table tennis ball for the Moon, a cardboard tube, plus a thin, stiff wire for the pointer.
Sundries include four M5 screws (40–50mm long), two Nylock nuts and five washers, three GT2 drive pulleys (with 20 teeth), a length of GT2 6mm-wide timing belt cut to 247-teeth (500mm long) and glue
υ For the finish you’ll need wood stain, matt black spray and yellow paint
Phases of the Moon
Illustration showing how the phases of the Moon are caused. Credit: BBC Sky at Night Magazine
Illustration showing how the phases of the Moon are caused. The inner ring shows how the Sun illuminates different parts of the Moon during the lunar cycle. The outer ring shows what this looks like from Earth. Credit: BBC Sky at Night Magazine
The real Moon’s phases take 29.53 days to complete their cycle from new Moon through the waxing phases to full Moon, then the waning phases back to new Moon.
This means there are 12.36 phases in one year of 365 days.
The year ring of our Moon phases calculator has 247 teeth on its inner circumference, driving the 20-tooth Moon pulley.
This ratio of 12.35 to 1 is very close to the real ‘phase-to-year’ ratio.
The slight difference might require a small adjustment if you fast-forward several years ahead, but once you know (or observe) the date of a new or full Moon, it is easy to re-calibrate the instrument.
Notes on building the calculator
lunar phase calculator 02 shaping ring
The trickiest part of the build is producing the smooth circular hole inside the year ring.
If you have a router with a compass attachment this isn’t too hard, but sanding by hand after cutting with a coping saw requires some care.
We devised a simple jig to hold our board after cutting out the approximate inside shape.
The jig can be held in a vice or clamped to a bench so that the board revolves about its centre.
You gently turn the board while a small sanding drum, fitted into an electric drill – held or clamped so the sander just touches the inside of the hole – smooths the surface.
We found it easy to make small adjustments to achieve the calculated internal diameter of 158.6mm, so that a section of belt with 247 teeth fitted perfectly.
lunar phase calculator 09 belt fitted
One of the pulleys, turned by the belt, is attached to the Moon ball.
The other two pulleys turn freely and are only used to guide the year ring and keep it in contact with the Moon pulley.
It’s best to drill the holes in the base for the two guide pulleys after fitting the Moon pulley, as you may need to make small corrections to ensure they will all turn smoothly.
We hope you enjoy making and using your lunar phase calculator; you may even wish to customise it by adding some decoration or using more sophisticated materials.
The calculator is great for planning observations, such as when you need a moonless night.
As well as its practical applications it’s an interesting talking point and looks good enough to display.
Step-by-step
moon phase calculator step 01
Use the drawings via the links at the top of this article and mark out the base and year ring.
Use the point of a compass to mark the centre positions of the three pulleys on the base; these will be confirmed before drilling.
Next, cut out the base and inside of the year ring.
moon phase calculator step 02
By temporarily screwing the year ring board to a simple jig (held in a vice), you can turn it so that a small sanding drum in a hand drill can smooth the inner circumference.
You can increase the diameter until the 247-tooth belt fits perfectly inside.
moon phase calculator step 03
After finishing and painting the year ring, glue the drive belt to the inner edge.
We also treated our plywood base to some wood stain and varnish.
While the glue is drying, cut out the card parts and paint them and the cardboard viewing tube matt black.
moon phase calculator step 04
Paint most of the table-tennis ball yellow, then, using masking tape to mask the yellow hemisphere half, paint the rest matt black.
Next, glue an M5 screw to the Moon ball so that when rotated, the Moon phases are shown.
moon phase calculator step 05
Loosely position the pulleys and year ring on the base.
One at a time, spot through with the drill, then drill a neat hole and temporarily fix each pulley with a screw.
Before drilling the third pulley make sure the fit is not too tight or the ring might bind.
moon phase calculator step 06
Add calendar dates to the year ring and assemble the moving parts.
Use packing to work out the tube’s height and make a stand from a softwood offcut and paint it black.
Drill a hole in the stand’s front to add a wire pointer and finish assembly.
Have you completed our build? Let us know by emailing contactus@skyatnightmagazine.com
