The Snow Moon is coming this weekend. How to see the second full Moon of 2026
How to make the most of February's full Moon, known as the Snow Moon.
The February full Moon is the Snow Moon, the second full Moon of 2026, rising on 1st February at around sunset.
The full Moon is an amazing sight, and it's incredible how much that brilliant lunar glow lights up our surroundings on a clear night.
Amateur astronomers often bemoan the full Moon, as it can wash out deep-sky objects like star clusters and galaxies.
But a full Moon is a great spectacle for beginners and young astronomers, or indeed anyone who loves to marvel at the night sky with the naked-eye.
There's much to enjoy if you're stepping outside to enjoy the Snow Moon.
Sign up to the BBC Sky at Night Magazine e-newsletter for lunar times and phases delivered to your email inbox every week.
Photograph of the Snow Moon rising over Glastonbury Tor, Somerset, UK, 26 February 2021. Credit: Matt Cardy/Getty Images
Why it's called the Snow Moon
Each full Moon of the year has its own informal name, such as the Wolf Moon in January.
The Snow Moon is probably the easiest full Moon nickname to decipher, as it reflects the fact that it often snows in February, just before the season changes and spring makes an appearance.
In the Northern Hemisphere, January and February are normally the coldest, snowiest months, so it makes sense that February's full Moon would have a nickname reflecting that.
Observing the Snow Moon
This view of the Snow Moon and plane was captured by Mark Pelleymounter, Bournemouth, Dorset, UK.
The 1st February 2026 full Moon, or Snow moon, will rise in the east-northeast at sunset.
It will be just beside the constellation Leo and its famous Sickle asterism (an informal pattern of stars that's not a recognised constellation.
If you can see a bright star right beneath the Snow Moon, that's Regulus, the star that marks the bottom of the Sickle.
A chart showing the position of star Regulus in Leo
Credit: Pete Lawrence
Regulus is a jewel in the springtime sky and can easily be seen with the naked eye, so keep an eye out for it as March and April roll around!
Above the Snow Moon, you'll also be able to see the planet Jupiter forming a triangle with Castor and Pollux, the twin stars of Gemini.
Jupiter is one of the brightest objects in the night sky at the moment, and looks like a bright star to the naked eye.
When you're observing the full Moon, there are a few ways to make the most of its beauty.
Here are just a few. For more advice, read our guide on how to make the most of a full Moon or supermoon.
Does the Moon look bigger as it rises?
Full Moon over the Castle of Evoramonte Sérgio Conceição, Evoramonte, Portugal, 6 May 2023 Equipment: Canon EOS R mirrorless camera, Canon EF 100-400mm f/4.5-5.6L IS II USM lens
Full Moon over the Castle of Evoramonte by Sérgio Conceição, Evoramonte, Portugal, 6 May 2023
Ever heard of the Moon illusion? This is the name given to the optical illusion whereby the Moon looks much larger than usual when it's viewed closer to the horizon.
No-one knows exactly why this is the case, but one theory is that foreground objects look tinier when compared to the Moon, which makes the Moon itself appear huge.
You can break the Moon illusion by holding your arm out at length and covering the Moon with your thumb, proving it isn't actually as huge as it appears!
If you're observing the Moon rising, see if you can notice the edge of the Moon - known as the 'limb' - wobbling. This effect is distortion caused by moonlight rippling through Earth's atmosphere.
Look for a lunar halo
Lunar halo captured by Tom Wildoner, Pennsylvia, USA, 29 December 2020
A full Moon often sports a glowing ring or halo around the Moon.
This is caused by bright moonlight streaming thorough the clouds, causing the appearance of haloes and other atmospheric phenomena.
If you're observing the Snow Moon, see if you can spot any tricks of light caused by the bright lunar glare.
Observe, sketch, photograph and marvel
Photograph the full Moon with your smartphone. Credit: 	Brigitte Blättler / Getty Images
Don't be put off by advice telling you to avoid a full Moon, as it's one of the most beautiful things in nature that you can see with the naked eye.
Even a modest pair of binoculars will enable you to explore the lunar surface. Explore its craters and the lunar maria - or seas.
Perhaps you could try to locate the Apollo landing sites on the Moon.
If you're observing with friends or family, have a go at sketching the lunar surface, then compare your sketchings? You can find out more about this in our guide on how to sketch the Moon.
And have a go at photographing the Moon. If you have a smartphone tripod, mount your phone on it, and if your phone has a 'pro' photography mode, experiment by changing the ISO, white balance and exposure time to capture your image.
Read our guide on how to photograph the Moon with a smartphone for more advice.
And if you do capture an image of the Snow Moon, don't forget to send us your images.
