My telescope has silver spots on the inside of the lens. Should I remove the lens to clean them?
Published: May 3, 2020 at 7:23 am
My Celestron NexStar 8SE has silver spots on the inside of the lens.Should I remove the lens to clean them?
Steve says: "The Celestron NexStar 8SE is a very popular 8-inch Schmidt-Cassegrain telescope (SCT) mounted on an altaz Go-To mount.
Schmidt-Cassegrains are reflecting telescopes with a spherical primary mirror but they have a specially figured correcting plate on the front of the optical tubeto remove the aberrations that such a mirror would normally produce, namely spherical aberration.
Unless you know that the silver spots are spoiling the views through the telescope, which is unlikely, or that the spots are in any way organic or corrosive, which means that they could cause problems in the future, the best plan is to leave well alone.
Cleaning optics can lead to more problems than you solve as there is always the risk of micro-scratching the surfaces or worse.
However, if you do decide that the corrector plate must be cleaned then proceed carefully and methodically.
There is much debate over whether or not the corrector plate andprimary mirror in a given telescope are matched at thefactory but it makes sense to ensure that you can return thecorrector plate to its original orientation.
This can be done by removing the screws in the retaining ring and marking the edge of the corrector plate and the optical tube with an indeliblemarker before removal and subsequent cleaning.
However, a much safer approach is to return the telescope to the importer’s repair centre and letthem do the work for you."
