Opposition in astronomy and why it's the best time to see the planets
What an opposition is, why planets at opposition are good for observing and when is best to see them.
You may have heard the term opposition being used in astronomy before, and you may be wondering exactly what that means.
In astronomy, an opposition is the time when a planet or planetary body is in the exact opposite position in the sky to the Sun.
To put it another way, opposition is when the Sun, Earth and another planet or planetary body form a line with Earth in the middle.
Upcoming planet oppositions
  • Saturn - 21 September 2025
  • Neptune - 23 September 2025
  • Uranus - 21 November 2025
  • Jupiter - 10 January 2026
  • Mars - 19 February 2027
Why opposition happens in astronomy
Positioned on the opposite side of the Earth to the Sun, Jupiter is shown at opposition. Credit: Steve Marsh
Positioned on the opposite side of the Earth to the Sun, here Jupiter is shown at opposition. Credit: Steve Marsh
If you look at the diagram above, where Jupiter is shown at opposition, you’ll see what’s going on.
This shows the view looking down on the plane of the Solar System. Notice that only the planets further out from the Sun than Earth, known as superior planets, can achieve opposition.
On the diagram, imagine all the planets moving anti-clockwise along their orbits – the Earth moving fastest and each further planet moving more slowly as it orbits the Sun.
As Earth sweeps around, it will move between the Sun and every one of the planets. It is this orbital triple line-up of the Sun, Earth and a planet that indicates the time of opposition for each planet.
This is great news if you like observing these distant worlds, because it means the planet will appear at its largest and brightest in the sky.
diagram showing saturn at opposition
Diagram showing Saturn at opposition
Observing planets at opposition
From our perspective on Earth, opposition means that the planet is in the opposite part of the sky to the Sun.
This also means that only the superior planets – the five planets with orbits further out from the Sun than Earth’s – can be at opposition.
The inferior planets – Mercury and Venus – can’t get into this alignment.
In astronomy, a planet at opposition is usually at its closest to Earth and therefore appears larger than at any other time.
Due to its position relative to the Sun, when a planet is at opposition it can also appear brighter than usual, making this the best time to observe the planet on a clear night.
Any planet at opposition will rise at sunset, reach its highest in the sky at midnight and set at sunrise.
Therefore, you have your target as high as possible close to the darkest time of night. Everything is calling out for it to be observed.
Find out which planets are visible, month-by-month
Mars at opposition
The difference in the apparent size of Mars when it’s at its most favourable opposition and when at its most distant from Earth. Credit: Pete Lawrence
Mars is the first planet away from the Sun to us and also the one that shows the greatest change at opposition.
Most of the time, Mars is seen as a fairly small reddish disc in a telescope, but every two years and two months Mars moves into opposition.
As this event approaches, there is a dramatic increase in brightness over just a few weeks. Indeed, while sitting close to the Earth, Mars can become the second brightest planet in the sky after Venus.
During opposition you’ll see a planet’s change in size most clearly with a telescope.
With clear skies at opposition, Mars appears large in the eyepiece and you’ll be able to see incredibly fine details on the surface.
The triangular Syrtis Major can be seen in centre of this image of Mars. Note: south is up in the image. Credit: Pete Lawrence
As well as the larger areas such as the dark patch of Syrtis Major and the polar ice caps.
However, this sparkling ‘star’ does not last for long. As Earth’s faster orbital speed takes us away from Mars its size, and hence brightness, diminishes.
In fact, Mars has only a two-month window centred around opposition when it is best observed. This is why many keen planetary observers await such events with great anticipation.
Further out, due to the more sedate speed of the moving worlds, oppositions occur more frequently than those of Mars.
Jupiter Opposition 2021 Prabhu, Mleiha, UAE, 19 August 2021 Equipment: ZWO ASI462MC camera, Celestron 11-inch EdgeHD Schmidt-Cassegrain
Jupiter Opposition in 2021. Credit: Prabhu, Mleiha, UAE
Outer planets at opposition
Jupiter’s slow orbit means it travels slowly across the night-time sky at a rate of about one constellation per year.
The result of this is that oppositions come around every one year and one month.
You can use this time to get a closer look at the detail in the cloud belts and zones of this gaseous giant.
It is also very obvious, when at its largest, that Jupiter is a squashed-looking world, its fast rotation causing the planet to take on a more oval appearance.
The fact that the outer planets are vast distances away from us means that the brightness changes also become less pronounced.
Oppositions only make a few tenths of a magnitude difference to the brightness of Uranus and Neptune – the outermost planets in the Solar System.
This guide originally appeared in the April 2011 issue of BBC Sky at Night Magazine.
