How to make a comet model
Follow our simple DIY guide and make your own model of a comet using household objects. A great arts and craft project to stimulate young minds.
Published: January 22, 2021 at 7:30 pm
Comets are some of the most interesting astronomical objects to observe. Many of us will have enjoyed Comet NEOWISE during the summer of 2020, but these dusty ice balls have been studied for millennia.
Early observers treated them with suspicion as they were linked (incorrectly) to natural disasters, and often thought to signify the death of noblemen. Hence, their label ‘Harbingers of Doom’.
Here we'll show you how to make your own model of a comet. This is a great science lesson for kids as you can weave explanations of comet chemistry into the arts-and-craft fun.
Speaking of which, perhaps it's best to begin with a bit of space science.
And for more projects like this, read our 6 astronomy experiments that can be done at home or our guide on how to get kids interested in astronomy.
What are comets?
Steve Lewis managed to spot Comet NEOWISE over Stonehenge in the early hours of 22 July and photographed it using a Nikon D810 DSLR and Nikon 24-70 2.8 lens @ f2.8. Credit: Steve Lewis
Steve Lewis managed to spot Comet NEOWISE over Stonehenge in the early hours of 22 July 2020 and photographed it using a Nikon D810 DSLR and Nikon 24-70 2.8 lens @ f2.8. Credit: Steve Lewis
Comets are icy bodies comprised of rock, dust, water ice, frozen volatile compounds and some also contain long-chain hydrocarbons and amino acids.
They were formed from materials left over following the formation of the Solar System. The nucleus of a comet is usually between a few hundred metres and a few tens of kilometres across.
When their orbit brings them into the inner Solar System, solar radiation causes some of the volatile compounds to vaporise out of the nucleus. This gas and dust forms a slight atmosphere around the comet, called the coma.
The exact size of the coma varies from comet to comet. It often has a greenish colour to it because ultraviolet light from the Sun ionises molecules of cyanogen and diatomic carbon within the coma, which causes the ions to fluoresce green.
An outflow of gas from Comet 67P/Churyumov-Gerasimenko, which was studied during the Rosetta mission. Credit: ESA/Rosetta/NAVCAM – CC BY-SA IGO 3.0
As a comet gets closer to the Sun, the radiation pressure from the solar wind causes the tails to form. Comets often have two distinct tails: a dust tail and an ion tail.
The dust tail is material left behind as the comet speeds through space. Dust tails are usually curved, are a white and yellow colour because they reflect sunlight and are normally between one and 10 million kilometres in length.
The ion tail, or plasma tail, is comprised of ionised particles. As they interact with the solar wind, the ions flow out at high speed in a straight line directly away from the Sun.
Ion tails are often a glowing blue colour due to ionised carbon monoxide. They are tens of millions of kilometres in length.
C/2020 F8 (SWAN) José J. Chambó, Siding Spring, NSW, Australia, 27 April 2020 Equipment: SBIG STL-11000M camera, Takahashi FSQ-106ED astrograph, Paramount ME mount
Comet C/2020 F8 (SWAN), imaged by José J. Chambó, Siding Spring, NSW, Australia, 27 April 2020
Some rare exceptions reach a whopping 3.8 AU long, where 1 AU (astronomical unit) is the distance between Earth and the Sun.
Because the comet’s nucleus is usually rotating, both tails may have twists and turns in them.
Science lesson over: now make your own comet model!
Making models is a great way to learn about an astronomical object. Here we show you how to make a model of a typical comet using very basic materials that you probably have lying around at home.
Because the model contains different components for each part of a comet, it provides a great teaching opportunity during each step of the model-making process.
For the stand we used a gift box that still had its insert, giving an extra layer of support for the wooden skewers. Some Blu Tack under the holes will also give something extra to hold the skewers in place.
Made like this, the stand should be sturdy enough to support this very lightweight model, but if you need some extra weight, fill the box with rice or sand.
Make your model comet: step-by-step
How to make a model of a comet. Credit: Mary McIntyre
Using hot glue, stick a cocktail stick in the middle of the long edge of the foam sheet with about a third over the edge. Tightly fold the sheet into a cone shape, securing with staples and hot glue. Stick the cone into the polystyrene ball using the cocktail stick.
Cover the ball with cotton wool to form the coma and then cover the entire foam sheet with cotton wool or wadding using water-based glue. Tear the ends off rather than cutting them so the end of the tail has an uneven edge.
Fill the cone with cotton wool or wadding, then glue a long strip of cotton wool around the edge, continuing inwards in a spiral pattern. Then gently pull, tease and twist all the edges to form an irregular dust tail shape. Use hairspray to hold the strands in place.
Remove the tail, then paint the outside of the nucleus (or coma) pale green using a water-based paint. This recreates the classic green colour of the coma around a comet’s nucleus. Leave this to dry. Once dry, re-attach the tail.
Twist together the two pipe cleaners with a length of craft wire to form the ion tail. Leave a short length of wire at one end which you can fix into the polystyrene ball. Make sure that you stick the ion tail into the nucleus/coma at a different angle to the dust tail.
Make two holes about 8cm apart in the box lid. Paint two wooden skewers black and trim the blunt ends. One skewer needs to be 17cm, the other 22cm. Push the blunt ends through the box holes, then push the pointed ends through the nucleus and tail.
Mary McIntyre is an outreach astronomer and teacher of astrophotography. This guide originally appeared in the February 2021 issue of BBC Sky at Night Magazine.
