How to polar align a star tracker mount
Set up this vital piece of deep-sky astrophotography equipment via our step-by-step guide.
Take any photo of the night sky with a DSLR camera and after a certain length of exposure, the stars will start to trail due to the apparent movement of the stars (in reality, Earth’s rotation).
Not so long ago, you needed a large equatorial mount and some familiarity with the ‘dark art’ of image processing to track the movement of the stars for astrophotography.
Today, though, there are many small lightweight, star-tracker mounts that allow us to attach a DSLR camera with a lens or a small telescope and follow the stars’ apparent movement to get extended exposures.
These portable mounts still have one important thing in common with their heavier counterparts: they require polar alignment to track the night sky successfully.
The Southern Milkyway by David Slack, Prudhoe, Northumberland, UK. Equipment: Full spectrum modified Canon EOS1100d, Tamron 55-200 lens, ioptron sky tracker mount.
Crisp stars of the Milky Way captured by by David Slack using a Canon EOS 1100D DSLR camera, Tamron 55-200 lens and iOptron sky tracker mount.
What is polar alignment?
Most star tracker mounts use a small polarscope to align on Earth’s axis of rotation, which, if you extend this line out into space, is slightly offset from the easy-to-locate Polaris (Alpha (α) Ursae Minoris) – the ‘North Star’ or ‘Pole Star’.
Aligning usually means placing the star roughly in the polarscope’s field of view and rotating the right ascension (RA) axis to the correct point, to position Polaris into a small circle on the graticule: the ‘clock face’ pattern that is seen through the eyepiece of the polarscope.
In some cases you can align an engraved set of constellations on the graticule (such as Cassiopeia and Ursa Major) with their positions in the sky.
The distinctive ‘W’ shape of Cassiopeia. Credit: Michael Breite/Stefan Heutz/Wolfgang Ries/ccdguide.com
Your level of success, however, is determined by how accurately you can perform the alignment for your equipment and requirements.
A large system with a telescope needs to be more accurately aligned to track the stars successfully.
It is possible to do this using the Sun, provided you are very careful and know what you are doing. But this must be done with extreme caution to avoid damaging your eyesight.
For more info on this, read our guide on how to polar align during the day.
Polar alignment and exposure times
Magnitude is represented on star charts by size: Polaris is brighter than Beta (β) Ursae Majoris. Credit: Pete Lawrence
Polaris can be found in Ursa minor. Credit: Pete Lawrence
Let’s look at how a DSLR star tracker can help increase exposure times with polar alignment.
If you are using a star tracker and a camera with wide-field lenses (up to 35mm) then an approximate alignment with Polaris in the centre will typically produce exposures of a couple of minutes.
In contrast, if you perform a proper polar alignment, you can push the exposures up to 10 or even 20 minutes with the same lenses, depending on the level of light pollution.
So, the ability to polar align is vital for getting the most out of your DSLR star tracker.
In addition, the more accurately you can perform the polar alignment, the longer lenses and exposures you can employ, despite the increased weight on the system.
Tibet Milky Way by Jeff Dai, Sichuan province of China. Equipment: Canon EOS 5D MarkII, AF-S Nikkor 14-24mm f/2.8G IF-ED, Loptron SkyTracker
Tibet Milky Way by Jeff Dai, Sichuan province of China. Equipment: Canon EOS 5D MarkII, AF-S Nikkor 14-24mm f/2.8G IF-ED, iOptron SkyTracker
Our preferred method is to use either the Sky-Watcher SyncScan Pro app (for Android and iOS) or the iOptron Polar Scope app (for iOS only) to show where to place Polaris on the graticule, based on the hands of a clock.
By ensuring that the ‘0’ is lined up with the vertical axis of your mount while looking through your polarscope, you can then use either one of the apps to help you position Polaris correctly.
For help with this, follow the step-by-step guide below.
Once you’ve followed the steps you can look forward to capturing great data and producing stunning images.
You can also use the same method to align your heavier equatorial mount.
You will need
  • Star tracker
  • Polarscope illuminator
  • Tripod
  • EQ wedge or a tripod with a normal pan head
  • DSLR camera with assorted lenses
How to polar align a star tracker mount: step-by-step
polar align star tracker mount step 01
  • Assemble your star tracker.
  • Attach it to a tripod and roughly aim it towards the north.
  • Use an equatorial wedge to help with latitude adjustment or try angling the tripod’s panhead.
polar align star tracker mount step 02
  • Ensure that your setup is level by using the spirit level integrated into the wedge.
  • Uncap the mount covers to reveal the integrated polarscope.
  • Use altitude and azimuth adjustment knobs to roughly place Polaris near the centre of the polarscope’s field of view.
polar align star tracker mount step 03
  • Attach the polarscope illuminator or use a red torch to illuminate the graticule.
  • Unlock and align the RA axis by sighting through the polarscope and rotating it until the graticule has ‘0’ at the top and is in line with the mount body.
polar align star tracker mount step 04
  • Using either the SynScan Pro app or the iOptron Polar Scope app, find where Polaris should lie along the circle of the graticule for the particular time and date that you’re out under the stars.
polar align star tracker mount step 05
  • Using the altitude and azimuth adjustment knobs, sight through the polarscope and position Polaris on the graticule as indicated in the app.
  • Remove the polar illuminator and add the camera with a wide-field lens, and start taking exposures.
polar align star tracker mount step 06
To get closer to your objects, fit a longer, heavier lens.
  • Use the mount’s (optional) dovetail L-bracket and counterweight shaft with the counterweight attached.
  • The bracket has a slot that will allow you to polar align with extra photography equipment attached.
This guide originally appeared in the February 2022 issue of BBC Sky at Night Magazine.
