How to set up an equatorial mount
Read our guide to set up your telescope's equatorial mount and get observing the night sky in no time.
Equatorial mounts can be a bit of a mystery if you’ve never used one before, but they don’t come much simpler than the EQ-1, which many small telescopes come with.
It may be easier to set up a camera-type altazimuth (altaz) mount, but an equatorial mount has the advantage of only needing to be rotated around one axis to keep your target object in the field of view, rather than two.
There’s a simple explanation for why this is the case.
Our planet also has an axis, tilted at 23.5°. As Earth rotates around this axis, the stars appear to move against the background sky over the course of the night, rising in the east and setting in the west.
In order to follow this movement the telescope has to be moved slowly in the opposite direction to Earth’s rotation: in other words, following the stars.
Difference between an altaz and an equatorial mount
Altaz mounts are popular and easy to use but won’t keep celestial targets stationary in the view frame, unlike equatorial mounts which are polar-aligned to stop the field of view rotating
With an altaz mount, doing this requires you to adjust two axes, azimuth (left-right) and altitude (up-down).
Properly set up, the polar axis of an equatorial mount is parallel to Earth’s axis of rotation and, therefore, doesn’t need to be adjusted further.
You just have to rotate the telescope’s other axis – the declination axis – to stay on target.
Once you are familiar with how to set up an EQ-1 in this way you should find it easy to get going and be able to maximise your time out under the night skies.
The simple steps set out below tell you how, and most of them can be performed during the daytime in anticipation of a clear night’s observing.
The various sections of an equatorial mount. Credit: BBC Sky at Night Magazine
Finding true north
When assembling your mount, make sure it is as level as possible – use a small spirit level on the tripod head before attaching the mount head.
Position the completed mount so that the polar axis (the oneyou’re going to tilt) roughly points north.
The next step is to set it to true north, which can be several degrees east of magnetic north from the UK.You can find out the magnetic variance of your location using the British Geological Survey’s snappily named ‘Grid Magnetic Angle Calculator’.
Use a compass to adjust your mount away from magnetic north accordingly.
To get the polar axis aligned properly you’ll need to set it for the latitude of your observing site. You can do this by checking your position against an Ordnance Survey map or online at www.latlong.net.
Take some stiff card and mark out a right-angled triangle that has one angle equal to your latitude.
For example, if you were in London you would be at a latitude of 51.5°N, so you’d need a triangle with an angle of 51.5° too.
How to set up an equatorial mount step 05
This triangle gives you a template that tells you how much adjustment you need to make to the polar axis to achieve polar alignment.
Hold it against your mount, with the longest side against the polar axis, and place a spirit level on the shortest side – which should be uppermost.
Turn the altitude adjustment bolt until the spirit level is level; the polar axis should now be parallel with Earth’s axis.
If the mount’s wormwheel prevents you from placing the template close enough, you can cut a slot out of the longest side without affecting its usefulness.
Home in on Polaris
The Plough’s stars are a great first target from which you can star-hop to other constellations. Credit: BBC Sky at Night Magazine.
The north celestial pole lies within 1° of Earth’s rotational axis. If you point your telescope so that it is parallel to the mount’s polar axis, Polaris - the north star - should now be in the field of view of a low power eyepiece.
It will also appear in the view of a finderscope, providing this has already been aligned with the main scope.
You can do this during daylight by centring a distant object in your telescope’s eyepiece and checking whether it also lies behind the cross-wires of the finder. Find out more in our guide to polar aligning during the day.
If it does not, turn the finder’s adjustment screws to achieve alignment.
You can check the accuracy of your polar alignment on any clear night by loosening the polar axis clutch and steadily rotating the telescope around this axis.
If you are accurately aligned, Polaris should travel in a small circle within the finderscope’s field of view.If not, make small adjustments to the altitude and azimuth of the mount head until it does.
You are then ready to use your mount.
Equipment
Compass
Ideally, one that shows angular degrees and is easy to read under red light.
Markers
Something to mark the position of each tripod leg after you’ve polar aligned your mount, to make the process quicker in the future. What you use depends on the surface you set up on.
Red light torch
Not only will a red light torch help you set up in the dark, it will protect your precious night vision while you do it.
Spirit level
A small pocket sized one, preferably circular, to make it easier to level the tripod.
Sundries
Make your triangle templates using a protractor, a pen, stiff card and scissors.
Step-by-step
How to set up an equatorial mount step 01
Decide where you are going to place your tripod.
It’s useful to pick a single location as you can then mark the position of each leg on the floor after Step 4, making it speedier to set up in the future.
Consider using a garden slab – this will give you stability too.
How to set up an equatorial mount step 02
Set up and level the tripod.
Extend the tripod legs to a comfortable height suitable for the type of telescope you are using, then use a spirit level to ensure the top of the tripod is as level as possible.
Make sure all the bolts are tight.
How to set up an equatorial mount step 03
Mark the height of each leg once levelled.
This will help you set up a bit quicker next time you head out observing, providing you plan to position the tripod in the same place – use the markers next time and you’ll find the tripod is near-level from the start.
How to set up an equatorial mount step 04
Install the mount head and roughly point the assembled mount northwards.
You will need to align to true north rather than magnetic north.
Once you’ve worked out your magnetic variance, use a compass to offset the mount as necessary.
Make a right-angled triangle template from stiff card – this will be the tool you use to set the polar axis to the correct angle.
Remember, one angle of the triangle needs to match the latitude of your observing location.
How to set up an equatorial mount step 06
Hold the template and spirit level against the side of the mount’s polar axis as above; you many need to cut a space in the template for your mount’s wormwheel.
Now adjust the angle of the polar axis. When the top of the template is level, the mount is ready to use.
This ‘How to’ originally appeared in the January 2014 issue of BBC Sky at Night Magazine.
